Skander09 писал(а):Восьмёрка если карбовая, то да, рассчитана 92ой. Инжекторные машины ВООБЩЕ ВСЕ рассчитаны на 95ый. Иномарки начиная с 90-ых годов тоже все рассчитаны на 95ый, потому что в большинстве западных стран 92го нет в продаже.
Выдержка из руководства по эксплуатации:
FUEL USAGE STATEMENT
CAUTION
Using leaded gasoline in your car will damage
the catalytic converters and heated oxygen
sensors, and affect the warranty coverage
validity.
This vehicle must use unleaded gasoline only.
This vehicle has a fuel filler tube which is especially
designed to accept only the smaller-diameter
unleaded gasoline dispensing nozzle.
2.4L model is designed to operate on unleaded
gasoline having a minimum octane rating of 87
[(MON + RON)/2], or 91 RON.
3.0L model is designed to operate on premium grade
unleaded gasoline having a minimum octane rating
of 91 [(MON + RON)/2], or 95 RON. If premium
grade unleaded gasoline is not available, unleaded
gasoline having an octane rating of 87 [(MON +
RON)/2], or 91 RON may be used. However, the
performance level may be reduced.
